Proper x Dimension on a 23 Velocity
I believe you want the prop shaft about 3 1/4" below the pad which equates to about an 18 1/2" X. This set up works great for boats powered with 320 to 425 HP. If you have less HP than that you might want to lower it a bit to help get on plane.
