hard pull to the left >
Old 07-31-2007 | 09:27 PM
Default hard pull to the left
OK, I took the boat I am buying out on a test run this morning and when getting into the throttles it pulls real hard to the left once I got it over 3000-3500 rpm's. Does anyone know what would cause this and how to fix it? The boat is a 28' Century Ultra II w/ twin 454's and bravo 1 drives. Both drives are standard rotation also. Thanks in advance.
Brandon
Brandon is offline
Old 07-31-2007 | 09:31 PM
Audiofn's Avatar
Charter Member #232
Could be as simple as the skeg after the prop turned the wrong way?
Put your best foot forward!
Audiofn is offline
Old 07-31-2007 | 09:34 PM
Sorry this may sound dumb but what exactly do you mean?
Brandon is offline
Old 07-31-2007 | 10:44 PM
Audiofn's Avatar
Charter Member #232
On some boats they have a fin that hangs off the zinc anode. If it is turned wrong then it can cause steering issues at speed.
Audiofn is offline
Old 08-01-2007 | 01:33 AM
What do you mean " standard rotation" ?????????
They are both spinning right????? If they are then its gonna do that. One should spin RH and one LH.
Griff is offline
Old 08-01-2007 | 02:53 AM
MOP
Hmmm Bravos and both spinning right, pretty stupid something is wacked! Asked why it is setup WRONG!!!!
MOP is offline
Old 08-01-2007 | 06:36 AM
Yes, I mean both spinning right by stardard rotation. And the fin and zinc anode are gone off both drives. Do you think putting some back on with the fins would help? Thanks everyone.
Brandon is offline
Old 08-01-2007 | 06:51 AM
jeff32's Avatar
I had one back couple years spinning same direction and let me tell ya... it just never pulled like that, not on the right, not on left either... not even when backing off throttle... my thought is this... you probably have either a play in the sterring system, or most probably, the shaft on the top of the gimball ring are worn. I had boats doing this because of this pin. they are pretty expensive to change, aroung 700-800$ each shaft plus labor if I recall right. but it does what you says, and specially backing off the throttle. have someone look at the transom plate inside the boat, (he could even hold the steering shaft) while you are outside the boat, then move the drives from left to right. if as soon you move the drive, and on the inside it makes everything move at the same time (steering cable) problem is more up front, but if you move them lets say an inch or 2 from left to right, and the shaft steering shaft on the inside does not really move, then it is probably the gimball ring shaft...
Hope it helps...
jeff32 is online now
outriggers
Drives and Lower Units
16
10-31-2008 06:29 PM
thanks_don
15
09-23-2007 11:06 PM
tomtbone1993
02-07-2006 06:15 AM
