prop help >
prop help
prop help
Old 08-02-2007 | 07:55 AM
Default prop help
i have a 271 fastech with a 540ci blueprinted haul with 1inch imco shorty curantly running 77.9mph@5000rpm moter is maped@5450 looking turn about 83to81mph what prop could i use 77.9 was done with a 28p ears where cut down about .5-half inch not looking for hole shots just top end
tony manzella is offline
Old 08-02-2007 | 08:50 AM
Pat McPherson's Avatar
What drive ration do you have?
If 1.5, then I'd say you're doing well slip wise with 78 @5000rpm.
Try a 26p Bravo 1 to get the rpm up to 5400...
Patrick
Pat McPherson is offline
Old 08-04-2007 | 07:55 AM
HEY PAT talked to merc preformance in wi told me to use 30p try it get rpm,s mph call them back and will lab it after that i should pick up about 300rpm or so yes i do have a 1.5 shorty on it THANK,s
Old 08-04-2007 | 09:40 AM
I'm not quite sure why they would tell you to go bigger. You were turning 5000 with a 28p, right?
You want to get rpms up to 5400, right?
Your going to lower rpm with a 30p.
I'd say try a stock 26p and a stock 28p and go from there...
Patrick
Old 08-04-2007 | 03:29 PM
took barge out this AM ran it at river turn 78.1 @ 5200 motor is still fresh mabe only 10 hrs on it T CROCKETT DYNO IT gave all info to merc by land line and we came up with a30pitch maybe high for now but ill run it get number,s and lab it BE HAPPY TO LET YOU KNOW THE OUT COME thank,s TONY MANZELLA
Old 08-06-2007 | 08:42 AM
throttleup's Avatar
Let the motor loosen up, make adjustments and then baseline.
Julie
throttleup is offline
Old 08-11-2007 | 01:19 PM
PAT / JULIE took the barge out with the 30p stock brv 76.2 @4600 STARTS GETTING ignorant chine walking , see first msg forgot to say 2 other people in boat at that time. tomarrow going to try again with a tuppaware box and 2 to 4 bags of sand in cabin still got a little juice left on throtle if any other ideals please reply (THANK YOU BOTH) tony M CHICKEN!
Sick Stinger
Velocity
9
02-07-2008 11:39 AM
FlyFast
1
08-06-2004 10:22 AM
boatinbill
07-26-2002 09:58 AM
MIKEHTMSR24
07-22-2002 03:18 PM
MIKEHTMSR24
0
07-22-2002 01:40 PM
