Stock BBC Oil Oil Pump Cavitation >
Old 08-06-2007 | 07:26 AM
Default Stock BBC Oil Oil Pump Cavitation
what can cause the pan to run out of oil in a BBC, six quart pan, stock oil pump?
djtalon is offline
Old 08-06-2007 | 08:22 AM
If your running WOT you could be pumping it dry. Thats why most boat have at least 8qt pans. You also my have your pickup to close to the bottom of the pan. That will cause the same symptoms. I think around 1/2" clearance is needed.
kennyo is offline
Old 08-06-2007 | 10:20 AM
CigDaze's Avatar
You need more oil, bigger pan.
A buddy blew up his 454 chevy truck last weekend towing a large load up the skyway bridge - steep incline, 2 miles long. He was running around 4400 rpms and just pumped all the oil to the top, ran the bottom end dry. Boom!
You definitely need a big pan in a marine application.
CigDaze is offline
copiercat
25
11-10-2007 02:32 PM
TwinTurboStroker
4
06-29-2005 04:28 PM
Comanche3Six
2
12-30-2004 05:09 PM
HOTROD2
16
06-25-2003 06:44 PM
27 FOUNTAIN
12
01-18-2002 07:25 PM
