I need scan tool for 496 HO >
Old 08-13-2007 | 11:52 AM
speedygonzalez's Avatar
Question I need scan tool for 496 HO
I broke a valve spring while docking the boat at idle, I replaced all valve springs and added a pair of lightning headers while I was at it, but now I get two beeps while at idle. Now the question , did the valve spring trigger the alarm or it possible that the headers are causing some kind of water
tempeture or presure problem.
The port side risers run @20/35 degrees hoter .
I need to buy a scan tool I'm trying to make Havasu this weekend.
speedygonzalez is offline
Old 08-13-2007 | 02:08 PM
just ordered scan tool ($$$$$) I hope to get it tomorrow. I almost think it's my IAC because when I rev up slighthly I get a faint drop in rpm then it picks up. It problably has nothing to do with valve breaking or new headers.
Old 08-13-2007 | 08:54 PM
Dave_N's Avatar
Do your headers have a temp sensor? if you disconnected the original manifold temp sensors and did not reconnect to anything, that would cause an alarm. I guess Im'm a little late, but I just listed a DDT type scan tool on ebay.
Dave
Dave_N is offline
Old 08-14-2007 | 06:46 AM
LAKESIDE RESTORATIONS's Avatar
Lakeside Restorations.com
Im thinking manifold temp & waterflow (balancing) issues thru the new headers... This has happened a lot latley on the 496's... Jamie / Lakeside
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
LAKESIDE RESTORATIONS is offline
Old 08-14-2007 | 08:04 AM
I suspect it could be a water balancing flow problem as well, if you take laser temp reader and aim it at each riser the front port side is @40 degrees hoter than the rear starboard riser,however, the difference at each temp sensor is only @ 10 degrees not enough to trigger an alarm.
I also believe it could be my water hose presure. Ihave a well with a pump presure fluctuation of 40 to 20 lbs. So it may be that at its lowest it triggers low water preasure (if it is equipped with) sensor.
Old 08-15-2007 | 01:14 PM
got the scanner and the only code that it had was ECT temp hi. It turrned out to be that a pin on the coolant temp sesor had been pushed out during the install and thus causing alarm to sound off.
Harper220
12
12-05-2019 07:48 PM
Griswald
4
07-22-2007 02:09 PM
jhoward
07-08-2007 11:26 PM
jayhawk261
Grand Lake/LOTO/E-Dock
0
04-07-2007 12:09 PM
Dave_N
13
02-11-2007 11:20 AM
