525 SC's oil change >
525 SC's oil change
525 SC's oil change
Old 08-22-2007 | 06:39 PM
Tony Montana's Avatar
The BAD Guy
Default 525 SC's oil change
I am going to be changing the oil on my 97 525 sc's. I just got the boat so I need some advice. The old owner said he was running synthetic and lost a lobe on the cam. He said he had the top ends rebuilt and switched to a straight 40 weight. So what oil (Brand/Weight) do you guys recommend? Also does anyone have a good place that I can get the oil and filter from? Does anyone know what filter (part number) I need? Thanks
Tony Montana is offline
Old 08-22-2007 | 06:49 PM
jeff32's Avatar
your merc dealer!
jeff32 is offline
Old 08-22-2007 | 06:57 PM
Read the topic "Marine lubrication" it may shed some light on the subject. I run a WIX 1060R filter with Mobil 1 V twin oil. There are many opinions on oil and filters, run what you feel comfortable with.
Old Navy is offline
Old 08-23-2007 | 03:52 AM
I always ran 15-50 Mobil 1 in my 525sc every 25-30 hrs. Cam was still perfect at 350 hrs when I upgraded it to a roller cam and lifters looked perfect as well.
Griff is online now
Old 08-23-2007 | 04:59 PM
Make sure you suck the oil out of the blower and change that too. My book from merc says you can run Hi-perf gear lube. I run 75W90 Royal purple, same as the drive.
Old Navy is offline
Old 08-23-2007 | 05:36 PM
just run some good 20 - 50 dino oil or spend the $ on some synthetic or merc oil
mikebrls is offline
Old 08-23-2007 | 07:54 PM
all you need to know tuff guy..
you will have all the answers if you can read all this
http://www.offshoreonly.com/forums/s...ht=lubrication
mikebrls is offline
prholley
Do It Yourself, Boating on a Budget
12
09-08-2008 01:11 AM
Hank36
Baja
6
06-16-2007 06:32 AM
NASCAT
07-12-2006 07:02 AM
iamfaster
6
10-17-2004 07:21 PM
kathycool
2
09-30-2002 07:51 PM
