PUTNAM class 5 hitch
Old 08-22-2007 | 06:41 PM
Default PUTNAM class 5 hitch
I just purchased a Putnam class 5 hitch on the advisement of people on this list to pull my 38' Scarab. I picked it up on the internet from a place in New Mexico called Sportztrailers. The thing is , physically it looks almost like the one that came off (class 3 I think-1999 F350 dually). Then to add to that my muffler guy said it probably isn't a class 5 because it doesn't have a 2 1/2 " receiver. He said I should have got a Titan. Honestly I don't have any worries about it but who knows. What do you guys think.Mike
Michael Garibay is offline
Old 08-22-2007 | 07:33 PM
buck183's Avatar
What's the part number on the hitch? Should be able to look it up on Putnam's site and very the rating with the part number.
Keep in mind, a hitch does not have to have a 2.5" receiver to be a class 5 either.
Buck
buck183 is offline
Old 08-22-2007 | 07:58 PM
haulinvols's Avatar
www.Bajaboatowners.com
Buck
True, true.
I helped Chris (Dunnoit) a member here put a putnam Class 5 on his 2500 Dodge a couple years ago. It is a stout piece and fit well. The brackets were much longer on the Putnam than the stock piece, they extended up the frame further.
haulinvols is offline
Old 08-23-2007 | 08:37 AM
J.B. Marshall's Avatar
JB Marshall
I installed a Putnam class V a few weeks back on my F250 and when I removed the stock hitch you could not tell the difference for the exception of the weight info on the stickers.
It did have a 2 1/2 receiver.
J.B. Marshall is offline
Old 08-23-2007 | 11:23 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
SOME of the Fords have true Class-V hitches from the factory. However, many of them say "V-5" on them, and are really Class-III hitches intentionally labeled to make you think they are heavier.
I do believe that the Factory Ford 2.5" (rare) receiver is a true Class-V. I did order a Putnam Class-V for my 2000 Ford PSD Dually, and it is MUCH more stout than the 2" Class-III hitch that Ford installed.
Michael, it sounds like the hitch you removed WAS a true Class-V hitch from Ford.
The biggest issue with the Putnams is they ship with Grade-5 bolts. I upgraded my bolts before install to Grade-8 (from a local supplier), AND got the new ones long enough to double nut them. You MUST use the square collars that come with the Putnam hitch
Sydwayz is offline
Old 08-24-2007 | 01:43 AM
I did install the square washers with the hitch. The old hitch looked like the one on my old excursion. I'll do more research in the mean time. Mike
BillR
2
10-24-2007 08:36 AM
PremierPOWER
42
05-08-2007 07:38 AM
aquatictherapy
1
04-06-2006 01:03 PM
two-air
3
06-02-2005 08:55 AM
HavasuCat
05-31-2002 04:13 PM
