Trouble with outdrive! >
Old 09-15-2007 | 03:15 PM
fountainfevr's Avatar
Default Trouble with outdrive!
when put in drive I get a steady knockin sound and lost my reverse. Any thoughts on wht th problem might be?
fountainfevr is offline
Old 09-15-2007 | 03:27 PM
Knocking outdrive usually means broken gear. Check fluid for metal on drain plug magnets. Good Luck
Jim
MOBILEMERCMAN is offline
Old 09-15-2007 | 07:04 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Yeah, you are definitely broke. Probably the upper gear set, gear floor, and/or clutch/shift assembly.
Sydwayz is offline
Old 09-15-2007 | 07:59 PM
monstaaa's Avatar
anything thing that knocks will not be cheap.
i wish you the best.
monstaaa is offline
Old 09-15-2007 | 08:14 PM
BAJA WILL's Avatar
Registered User
Check all the above, however before you go pull the drive apart check your shift cable and make sure it is functioning correctly, it could be just out of alignment. It took three merc mecanics to figure that out on my Fever after two years.
BAJA WILL is offline
Old 09-15-2007 | 10:04 PM
Thanks ! From my experience anything for a powerboat is not cheap but Im sure this is worse!!!
Old 09-16-2007 | 11:22 AM
monstaaa's Avatar
we had a knocking noise in a bravo 3 that turned out to be a loose carrier retainer.
monstaaa is offline
Old 09-16-2007 | 11:33 AM
This is prolly a dumb question but the only way to get in th outdrive is to take it off? next question will I need an alinment tool to put back on?
Old 09-16-2007 | 06:45 PM
monstaaa's Avatar
answer , yes.
this way you can check engine alignment, and make sure you are not off.
monstaaa is offline
Old 09-16-2007 | 07:24 PM
I think I better take it to a professional. You know I dont drive hard keep maintence up and then get treated like this but thats the graet life of boating
mikebrls
Members On-line Video Section!!
103
09-26-2008 08:10 PM
SCBoater
09-25-2008 06:41 PM
Game On
8
01-03-2007 08:25 PM
