Prop advice for 24 cheetah stiletto >
Old 09-15-2007 | 06:28 PM
Default Prop advice for 24 cheetah stiletto
I currently run a bravo 26. I am running mid 70's at around 4800rpms, with 450 lbs of adult and low fuel
i like to run at 4000 rpm's mostly.
I have 790 hp and 1.5 gr in a bravo1 imco lower.
i am wondering about a 5 blade prop and one for loaded family weekends.
This boat is a mod v i can provide pictures if needed.
thanks in advance.
Scapegoat1 is offline
Old 09-17-2007 | 07:58 AM
throttleup's Avatar
Can you give us the specs on the motor ie:
RPM at which peak torque is produced
RPM at which peak HP is produced
Julie
throttleup is offline
Old 09-17-2007 | 08:00 PM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Because you are running very efficient per the info supplied, 5 blade propellers may only help in the low to mid rpm numbers for cruise and hurt up top. My early thoughts are that of a reduced diameter if 5 blades can be made to work. Also lower pitches may be needed per the response to Julie's question.
[email protected]
bbladesprops is offline
Old 09-18-2007 | 01:25 PM
@5000rpms 793 lb-tq
@6000rpms 793 hp
I like to keep it between 3500rpm-4500 most of the time.
here is a link to the dyno and some pics
http://www.hotboat.com/image_center/...=&ppuser=17392
Old 09-18-2007 | 01:26 PM
I am also templating the idea of a 28 prop
Old 09-18-2007 | 04:59 PM
throttleup's Avatar
With the 26P Bravo I what is your WOT RPM? Is it the 4800 @ mid 70's?
Julie
Old 09-18-2007 | 08:49 PM
I have had it to 5200 rpms did not gps that run
water pick up nocking around 80mp,I am aslo still learning the trim.
Old 09-18-2007 | 09:14 PM
throttleup's Avatar
Ok, then I really think for one we need ot get your RPM up to at 5700 RPM at WOT for starters. Can you get me a clean run on a stock propeller, please? With GPS if possible.
Julie
Old 09-18-2007 | 09:41 PM
I will follow up after next trip, I will try to make a speed pass solo with the gps.
paxtonsc
Prop Talk
3
08-28-2006 07:33 PM
wheatieworld
Powerquest
1
08-06-2006 06:04 PM
29scarab
9
08-25-2004 10:38 PM
Elite Marine
Pantera
5
05-12-2003 06:35 PM
powerqrudy
4
06-05-2002 01:39 PM
