500 EFI's
From: Ft. Lauderdale Florida & Tarpon Springs Florida
I posted in the technical section, but wanted the exposure here.
I am looking at a Top Gun with 500 EFI's and it is not enough power. Any easy ways to boost power with that engine ? rebuild top ends?? add supercharger ?? can I keep the injection with a supercharger like the new 600 or 700's?
thanks for the inlut in advance
Depending on the hours on the engine, Vortech and Whipple make great kits without getting into the engine. I do recommend to get the heads off and do some maintenance and upgrades while you are at it either way. If you want to stay N/A, you can build a mild 650HP setup with 540ci's and Dart Alm. Heads.
Tyler Crockette was working on a upgrade to the 500 EFI when he boosted my carbed 500 to 650 hp. I would contact him. I think what you want to gain can be done without a problem. Then you might want to make sure your drive(s) are good that will be the next weekest link. Mine have been gone through as well and now I run turn key no problems well into the upper 90's with the boat full of fuel and people
I am just wrapping up with the re- do of the '98, but I want to get into a twin step. I just don't want to be afraid of the 500's and so far the input has been good that I can get anywhere from low 600HP to 700 HP without major overhaul, which will put me into the 90's !
Just what you're looking for:
http://www.whipplesuperchargers.com/...sp?ProdID=1150
I'd be interested in the EFI intake pieces.
