need prop help on a 28 cat
here is a question for you prop guru's, I'm running a 28 profile cat, 622 ci bowtie, natrually asperated, dyno # 827hp@5800 rpm, 834ftlb's @ 4700 rpm, Imco SC drive with stand off and 3 inch rise, drive ratio is 1.34 at 5600 rpm w/ 26p B1 runs 95 mph on gps, at 5200rpm w/26p B1 runs 88 mph on gps. hers's the question, if I run the slip #'s for a 26p B1 it's around 7.8% if I run the slip #'s for a 25p, which is what they claim I sould use it is around 4.0%, which # is correct, and is it possible to get that little slip out of a stock 26p B1, If I change over to a 5 blade will I get more speed.
thanks
Larry
thanks
Larry
You are correct in that you should use 25P when calculating slip. Now assuming that your numbers are accurate I would suspect that a 5B would possibly slow you down. At 4% you you are dialed in VERY well! Nice job!
Julie
Julie
Fountain38
07-01-2002 10:19 PM
