454 mag carb ignition module???? >
Old 09-25-2007 | 01:34 PM
Ran-Dom 32's Avatar
Default 454 mag carb ignition module????
I have what I believe is a thunderbolt ignition set up off a '95 454 mag, carbed motor - I am building a set of carbed 502's 600+HP over the winter, I would like to use the ignition's off my old motors but I'm not sure if there is a rev limiter (I need to turn above 5500 & also concerned about the timming curve on the old set up.
The module off the dist. has 454 mag & #'s 806745-6 if this means anything
Ran-Dom 32 is offline
Old 09-25-2007 | 02:10 PM
T bolt IV or T bolt V?
rdoactive is offline
Old 09-25-2007 | 03:19 PM
Ran-Dom 32's Avatar
not sure, whatever would have been stock equipment on '95 carbed Mag, How can I tell? marking's??
Old 09-25-2007 | 03:34 PM
Pretty sure that is a TB V module.
If it looks like this link its a TB V. Part # 28 has a similar number to what you posted.
http://www.mercruiserparts.com/Show_...CAL+COMPONENTS
Griff is offline
Old 09-25-2007 | 03:35 PM
The module would be marked Tbolt IV if it were a 4.
Does it look like these?
http://www.marinemechanic.com/site/page252.html
If not it's a V.
I think 95 was first year for Tbolt V. If so, it would have a knock sensor that controls advance. So the advance curve is variable.
Not sure if a rev limiter was even on that motor.
Old 09-25-2007 | 03:49 PM
Ran-Dom 32's Avatar
that what it is, with a knock sensor attached, so will this set up work?
Old 09-25-2007 | 05:31 PM
I'm pretty sure the rev limit is built into the module. I don't think it can be changed, but don't know for sure.
Griff is offline
Old 09-26-2007 | 01:14 PM
Ran-Dom 32's Avatar
anyone else?
Old 09-26-2007 | 01:33 PM
Do a search here in the tech section.
I recall some threads about changing the T bolt V module to a Crane unit that still uses the knock sensor. Also some about changing over to a T bolt IV module without the knock sensor.
Old 09-26-2007 | 03:55 PM
Ran-Dom 32's Avatar
thanks, there is a ton of info on this, but I'm not real clear, can I simply buy used TBIV modules & plug them in place of the TBV?
kennyo
4
03-01-2007 06:40 PM
Shore Thing
16
11-10-2006 03:42 AM
born2burn
1
09-22-2004 11:38 PM
Thunderstruck
0
06-02-2003 01:42 PM
