525SC Serial Numbers ??? >
Old 09-28-2007 | 09:41 PM
G Man's Avatar
Default 525SC Serial Numbers ???
Motor is a 96. Where can I find the Mercruiser serial numbers ? Just want to varify it is a real 525SC.
G Man is offline
Old 09-29-2007 | 09:16 AM
pkspx's Avatar
http://mercruiserparts.stemtostern.c...nceengines.asp
PHP Code:
MODEL       MAKE    CID   #CYLS      YEAR          SERIAL NUMBER
525 SC      GM     454     8          1991-1992     OD456000-OF348963
525 SC (GEN V)GM   454     8          1992-1995     OD456000-OF348963
525 SC (GEN V)GM   454     8          1996          OF615814-OF745215
525 SC (GEN VI) GM 454     8          1997          OF745260-OF877734
525 SC (GEN VI) GM 454     8          1997          OK000012-OL415623
575 SCI     GM     502     8          2000          OL601000-OL602090
575 SCI     GM     502     8          2001          OL306696-OL307026
575 SCI     GM     502     8          2001-2002     OM050000-OM053292
575 SCI     GM     502     8          2002 & up     OM900000 & up
pkspx is offline
Old 09-29-2007 | 09:20 AM
G Man's Avatar
Did they offer this motor in 96? Also, where can I find the serial number on the motor???
G Man is offline
Old 09-29-2007 | 09:26 AM
pkspx's Avatar
Yes, They made 525SC in 96. List updated.
pkspx is offline
Old 09-29-2007 | 11:45 AM
Numbers should be on the side of the block near the starter.
Darrell.
DMOORE is offline
Old 10-01-2007 | 11:49 PM
On my '96 525SC, I couldn't find the number either until I tore it apart. There was no riveted tag, but the engine was still wire sealed on the intake and crank pulley bolts.
I finally found it when I rebuilt the top end. The serial was stamped into the block behind the fuel filter seapump bracket, just below the cylinder head, if I remember correctly. Also the stamping was only about the same size as the type you are reading now.
Griff is offline
Pantera1
05-02-2006 03:50 PM
jr2
5
01-14-2005 05:37 PM
38vice
6
12-16-2003 09:17 PM
raynman
3
01-01-2003 09:41 AM
Iggy
2
01-25-2002 10:20 AM
