2000 500 HP w/whipple question >
Old 10-08-2007 | 12:31 PM
Formula311-SR1's Avatar
Default 2000 500 HP w/whipple question
Friend picked up a 2000 baja with a whipple charged 500 hp. When they did the sea trial they noticed oil coming out for the dip stick. Is this common on this setup?
Motor runs @ 5.5 lbs of boost, 350 hours, compression was 140 in all 8 cylinders.
Heads were freshened within 50 hours (receipts for all work)
Formula311-SR1 is offline
Old 10-08-2007 | 02:13 PM
Smitty's Avatar
Compressions numbers are low, and that would explain the oil coming out of the dipstick. That is the result of blow by past the rings. Time for a rebuild of the bottom end.
Smitty is offline
Old 10-08-2007 | 03:11 PM
That's what I was thinking, but the guy that helped him buy it keeps arguing with me saying all blower motors do it.
Old 10-08-2007 | 03:55 PM
Beak Boater's Avatar
Charter Member # 545
Yea....they all do that, the ones that are tired do. "Rings are worn, blowers are pressurizing the crankcase causing oil to be pushed out the dipstick. With only 5 lbs of boost, they are getting alot of blow by.
Beak Boater is offline
Old 10-08-2007 | 03:59 PM
I'm not sure about the 500HP but I have seen blowers installed and people forget to move the pvc and/or breather hose to the intake side of the blower. That can pressurize the crankcase.
Plane Silly is offline
Old 10-08-2007 | 06:39 PM
paradigm shift's Avatar
I would do a leak down test or have on done then you will know where the compression is going. 140 if the motor is stock other than the whipple is low. Leak down will tell you if the heads - valves are the problem or rings. Dipstick indicates rings for sure. Just what I would do.
paradigm shift is offline
Old 10-08-2007 | 08:15 PM
my boat did the same thing. could be as simple as putting silicone inside the cap of the dipstick..more common than you would think.. leak it down first....also check the valve covers and make sure they are vented..mine was vented and still had to put silicone in the dipstick cap...
chad1 is offline
Old 10-09-2007 | 06:55 AM
Canada Jeff's Avatar
Mine doesn't do it. 400 hours on the bottom, new supercharger at 350 hours. All is good.
Canada Jeff is offline
Old 10-09-2007 | 10:01 AM
Thanks guys,
Ran-Dom 32
Swap Shop
25
05-06-2011 11:10 AM
jhardee
Scarab
1
02-16-2010 10:30 PM
jmackin
Fountain
12
10-03-2008 03:56 PM
chad1
4
01-05-2007 03:37 PM
seahawk
2
08-07-2006 08:51 PM
