plug vs drive line gimle >
Old 10-08-2007 | 12:41 PM
later's Avatar
Default plug vs drive line gimle
what is the difference between a plug-in and a drive line gimble? im assumeing this is for transmisson boats only.
later
later is online now
Old 10-08-2007 | 01:54 PM
A bravo can have a plug in (standard) or drive line (for staggered) as well as transmission boats.
The gimbals/trannsom assemblies are the same. On the drive line units there is a drive flange, carrier bearing, and the bearing support that is bolted to the transom plate. It bolts in the same place that the rear engine mounts (bravo) or trans tailstock (transmission) would bolt to the transom assembly. The drive flange has a shaft that projects back towards the bellows that supports the horizontal shaft/U joint assembly from the drive.
The flange in front of that supports a drive shaft between the engine/transmission and drive.
Gary
rdoactive is offline
Lunatic Fringe
05-21-2007 08:04 AM
Lunatic Fringe
Drives and Lower Units
0
05-09-2007 07:21 AM
Ck1flyer
5
11-23-2005 01:07 PM
Intolerant1
7
06-12-2002 11:15 PM
