Mechanical Fuel Pump 500 EFI? >
Old 10-10-2007 | 08:52 AM
Dock Holiday's Avatar
Charter Member #34
Default Mechanical Fuel Pump 500 EFI?
I have a pair of 2002 model 500 EFI's and I fired them up on the hose this weekend and found that one of the mechanical fuel pumps that mounts to the sea water pump is leaking oil out the side. I always service the pump with freash oil and a new gasket between it and the water pump every year but it is not leaking at that gasket between them but out the side of the pump.
I need to replace it and was wondering if a standard pump from a local auto store was the same.
If so does anyone have a part number to reference?
Dock Holiday is offline
Old 10-10-2007 | 09:10 AM
Dock,
I think the Merc number you are looking for is 842429a01
BobbyB is offline
Old 10-10-2007 | 11:12 AM
Charter Member #34
Originally Posted by BobbyB
Dock,
Thanks Bobby,
That looks like the Merc number I found online but I did not know if a standard auto fuel pump would cross over with this one.
Dock
Old 10-10-2007 | 11:39 AM
Ted G's Avatar
The auto fuel pump will not have a nipple installed for the overflow tube. If the diaphragm fails it will dump fuel in the bilge.
www.cbpba.com
Ted G is offline
Old 10-10-2007 | 11:57 AM
Charter Member #34
10-4
Thanks I don't want that so I'll order from Merc.
Much appreciated guys.
Old 10-10-2007 | 02:20 PM
CIG3's Avatar
Check out KEith Eickert. He has a bullet proof pump that is much better than the Mercury one. Also the pump arm is differant than any automotive style pump.
CIG3 is offline
Old 10-10-2007 | 06:52 PM
Charter Member #34
Thanks very much. Their website leaves a little to be desired on the ugrade pump so I'll call them tomorrow. I see now what you guys are talking about on the actuactor arm.
Jim Diesel
2
09-03-2008 07:40 PM
BillR
27
08-10-2008 11:31 PM
cloudmaster_321
Do It Yourself, Boating on a Budget
2
05-18-2008 01:59 PM
Fountain38
2
05-16-2007 05:42 PM
Quest for Speed
4
02-12-2004 07:21 PM
