Bulkhead/body structural help needed
http://www.offshoreonly.com/forums/s...d.php?t=171586
This is a link to athread I posted in the Powerquest section about cracking of the bulkhead area. I figured this forum might get more attention. Please check out the link about the extent of damage to the bulkhead. Thanks in advance
Jigsaws idea may not be that bad..
The glass is fixable, but it is what you cant see. The unknown if you will that would or could be the bigger problem. If it is from a weak frame or rot then it can be a big expensive ordeal. That can make even a screaming deal end up being still an expensive ride, also dont forget about down time in having it fixed..
If you still are thinking about buying it, I would have it professionally checked to get an idea of if there may be more extensive damage inside..
Jamie / Lakeside
Jamie / Lakeside.
www.LakesideRestorations.com 570-639-2628
We Make Fast Toys Faster, Cool Toys Cooler and Old Toys New!.. Performance, Custom & OEM Parts & much MORE![/CENTER]
East Coast B
01-04-2005 07:08 PM
