Ford 6.0 shimming issue
Old 10-23-2007 | 12:07 PM
Question Ford 6.0 shimming issue
Has anyone noticed a shimming issue when towing. The shimmy is more noticeable when taking off from a dead stop. The shimmy works its way out. My truck is a 06' F350, full 4 doors with a long bed. I am only towing a 28 Heat which is about 6,300 lbs with the trailer.
Any suggestions???
Young and Dumb is offline
Old 10-23-2007 | 12:29 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Your Nordic on a trailer full of fuel is at least 7000 lbs.
Do you have aftermarket exhaust? I have a 4" MBRP on my 7.3PSD that was hitting my transmission crossmember when taking off as the motor torqued up; at a place where it was VERY hard to see. We (as in two different shops and myself) thought it was in the drivetrain for a long time.
Do you have any lift or tire mods? You could have your driveshaft in a bind; and/or your driveshaft may be out of balance.
Sydwayz is offline
Old 10-23-2007 | 02:16 PM
speedygonzalez's Avatar
I got some shimming after I put a 8" lift and 37" tires , I eliminated some by lowering the carrier bearring, but still have some .
speedygonzalez is offline
Old 10-23-2007 | 06:22 PM
My Alison tranny torque converter locking in at 2000 rpm can be felt under acceleration while towing my 17,000 lbs of boat & trailer. It feels kind of like a knocking shimmy I guess.
Is it in the steering wheel?
Maybe when your taking off, it's unloading the front suspension enough to cause a shimmy.
Cliff Dweller is offline
Old 10-24-2007 | 11:01 AM
I have a leveling kit and stock exhaust. I do have a SCT chip but it does not matter if I turn it off or not. I just started having this problem and know I am noticing it without the trailer.
You feel it come from the floor...
Thanks Guys!
Old 10-24-2007 | 11:10 AM
Sorry I forgot..... I has a 03' Black Limited Excursion with the 7.3 and loved it. I wish I never sold it. Installed an 8" Z-link kit (coil-over) and ran a 38" Nittos with 20" rims. She was sexy..... Forgot to mention she rain a 14.3 in the quarter.
She would bark a 3rd gear scratch with 38's
Old 11-06-2007 | 08:29 AM
Default shimmy
the f250 and 350 come from the factory with 2 different sized rear blocks. the taller usually in 4 door long beds. if yours has a 3.5" rear block a simple shim kit for the carrier bearing should fix the prob. ford wont have the solution, but your local off road store should have it.
Hideaway Transport is offline
pettem
Drives and Lower Units
28
08-02-2022 01:46 PM
J-Bonz
3
03-23-2007 07:01 PM
Sydwayz
8
08-08-2006 01:58 PM
russ
0
07-21-2005 04:35 PM
Biggus
7
04-14-2003 03:23 PM
