Drive On Trailer
Not sure we understand your question, can you elaborate as to why you can't drive onto your trailer? Both bunk(yours) and rollers are made to drive on.
Only thing I can think of that your trailer sounds like it doesn't have is a small set of pivoting bunks up under the lowest point of your bow. To assure it goes straight into the bow stop/winch combo.... which I'm not sure if you have or not.... Two large bunks in the back is all you need in the back which should be placed on the flat surface of your hull, basically keep it off the hull strakes.
Again, post a little more info describing why you can't drive it on the trailer so we might be able to come up with better suggestions for you....
Correct - I Don't Have A Set Of Pivoting Bunks To Help Guide The Boat - Only One Set Of 10' Bunks That Start From Transom - How Difficult To Install New Set Of Bunks And How Long Do They Need To Be
Sounds like you need the front centering bunks. Easy enough to mount if you have the crossmember(s). I think the wood is just pressure treated, or you can probably buy everything you need from any of the online trailer supply houses.
Too bad you're in OK, I don't use my rear bunks.
Handful - Thanks For The Pics - My Trailer Only Has The Two Large Bunks That Are Perpendicular To The Ground - Also Don't Have The Tall Guide Ons - Do They Help Or Are They Necessary - Also How Do You Post Thumbnail Images
I added the forward bunks to one of my trailers.....you'll need a couple 5-6 ft salt treated 2 x 6's and some black outdoor carpet (try to match what's already on your trailer). Go to a trailer supply store and buy what mounting hardware and cross members you'll need......this is custom and will need to be figured out based on what your working with...jsut copy the beams and mounts from the ones already on your trailer.
waterboy222
18
01-22-2008 10:00 PM
OldSchool
18
08-15-2005 11:15 PM
