Freeing up a corroded stainless/aluminum joint
Diamond Member #001
OK you chemists and shadetree repair experts, here's a good one for you:
I have a stainless part that is screwed into an aluminum part. This area has been assembled for several years and subjected to both salt and fresh water. Since the two materials have very dissimilar galvanic properties, they have pretty extensively corroded together. I have tried brute force, heat, and a good soaking with a spray lubricant without success. I have read that the phosphoric acid Coca-Cola will dissolve rust on mild steel, but does anyone know if this trick will work in this case as well? If not, I'm open to other suggestions as well.
Help!
Help!
Diamond Member #001
After bailing me out on the engine connector deal, you're going to let me down on this one? OH - Man!!!!
Maybe Brownie will know.......
Chuck, have you tried PB Blaster, best stuff I've ever used. If not, how big is this part?
Diamond Member #001
It's a 1"-14 thread into a thinwall aluminum tube. The tube was anodized, but has actually begun to corrode away completely now....
