never seize
Old 01-12-2008 | 12:14 PM
BY U BOY's Avatar
Default never seize
Is there a special anti seize that i should use with stainless and aluminum?
BY U BOY is offline
Old 01-12-2008 | 02:14 PM
Registered User
Permatex Nickel #771.
SS, Ti, nickel alloys, etc. It will also work on aluminum but it's not necessary- ordinary anti-seize is suitable except in hi-temp applications.
Chris Sunkin is offline
Old 01-12-2008 | 02:47 PM
BY U BOY's Avatar
So the permatex is ok to use with my exhaust manifold bolts?
BY U BOY is offline
Old 01-12-2008 | 04:59 PM
Strip Poker 388's Avatar
Rob
I was told the copper/brown wasnt good if salt water gets on it? And to use it on spark plugs on alumin heads because of the heat..
Strip Poker 388 is offline
Old 01-12-2008 | 05:31 PM
I've always used ordinary antisieze and have not had a problem except when I did not use it. I use it on the spark plug threads, head bolt area above the threads that contact the aluminum heads. I've had them sieze there before with no antisieze. Really any place where two dissimilar metals are used.
Ryan00TJ is offline
Old 01-12-2008 | 05:40 PM
Bostik Neverseeze was always what we used at Cosworth for exh threads and spark plugs.
Great stuff with different grades of nickel loading including Nuclear reactor grade.....
http://www.neverseezproducts.com/bostik.htm
Ruaraidh is offline
Old 01-12-2008 | 07:54 PM
Registered User
sure
tomtbone1993
04-12-2008 05:38 PM
gripit
16
03-26-2007 11:23 AM
nordic95
53
01-29-2006 05:25 PM
