What is the STRONGEST,LIGHTEST, SMALLEST,1X1.5  inline Transmission? ? >
Old 02-25-2008 | 10:07 PM
Default What is the STRONGEST,LIGHTEST, SMALLEST,1X1.5 inline Transmission? ?
I want to connect a BBC to an Arneson 6. And where would I get this Trans.? ? CHEERS AW
obads 31 is offline
Old 02-25-2008 | 11:01 PM
The only inline I have used on the 6 is a BAM. You can get a wet sump or dry sump rated for 1350 ft lbs. The wet sump is smaller since it does not have the oil pan on the bottom.
Eddie
Young Performance is offline
Old 02-27-2008 | 04:12 PM
DONZI's Avatar
The stock B/W 72C 10- 18 is rated up to 475 HP.
http://www.marinegears.com/catalog/cat-bw-dr1.html
Used ones are on Ebay frequently.
High H.P .or upgrade. Nopper Marine Trans. is in Ma also
.http://www.noppermarine.com/index.html
Are you using an Ext. box or moving the engine forward ?
2 different coupling system's required.I just finished this same conversion last fall.
Ken
DONZI is offline
Old 02-28-2008 | 09:25 AM
Brad Zastrow's Avatar
Bams are the best transmissions but still break under big hp. SCS crashboxes are the lightest, strongest and a real pain to shift. They are almost impossible to break.
Brad Zastrow is offline
Old 02-28-2008 | 10:20 PM
Rik's Avatar
Rik
arneson-industries.com
Offshoreonly Advertiser
Well you are not very helpful in helping yourself. You did not mention what style of drive you have or reference the reduction ratio in the post.
Let's see, you mentioned in the subject line "1 X 1.5 in line transmission"
I think you probably meant you need a transmission with a 1.5:1 reduction ratio for an in line Arneson?
If this is what you are in need of, then you need to look at the following:
Twin Disc 5050A
ZF/Hurth 63A
Velvet Drive 5000A
Each of these are designed to have a drop and a reduction ratio in them. A standard Velvet drive does not have a reduction ratio so they would be a 1:1 ratio which will not work well.
Each of these transmissions have a hp rating of around 500 hp max.
Rik is offline
Old 02-29-2008 | 09:16 PM
RIK I have a #6 that bolts to the transom and at this point has the motor in backwards hooked to a velvet drive 72C V-drive @ 1 to 1.5 ratio and that is conected to the "6" with a driveshaft under the motor. I want to re-rig the set up with the motor in frontwards and down lower into the V of the hull with a short;strong;light Transmission as possible maintaining the 1 to 1.5 gear. What do you suggest that could take up to 700 HP and TQ. This is a 26 ' single engine set up.
obads 31 is offline
Old 03-02-2008 | 11:30 PM
Rik's Avatar
Rik
CG wise what you have is a great setup.
Problem with turning the engine around is a transmission.
The only alternative is to use a Casale Z box with a regular velvet drive but your engine is going to move way forward.
Rik is offline
Old 03-14-2008 | 10:22 PM
Hang Time 27's Avatar
Is "Huber" still building 'em for big power - he's been around the longest. I've got to have my huber rebuilt - lost pump pressure after 10 or so years - lost his number.
Hang Time 27 is offline
Old 03-14-2008 | 11:15 PM
Elite Marine's Avatar
KE has a new design that was at the Miami show.
Elite Marine is offline
Old 03-17-2008 | 12:48 PM
Rik's Avatar
Rik
It's long, it's not a 1.5:1 final, it's not a down angle and it's not proven.
He needs something that will connect and give him a 1.5:1 final. I think the powerglides are 2:1-1:1. A big jump and not good for his final and his engine will have to be in the rear seats due to the installed length.
Rik is offline
302Sport
08-27-2008 08:18 AM
klaw
17
03-27-2007 12:37 PM
Mr. Gov'nt
18
02-06-2007 09:54 AM
Brad Zastrow
Skater
4
01-27-2006 02:38 PM
