Changing water pumps
Old 03-01-2008 | 08:40 PM
Default Changing water pumps
Whats involved in changing the water pumps on 250XS's with Sportmaster gear cases? Is one pump kit better than another. I have all tools and can use them. Thanks
Frank Galasso is offline
Old 03-03-2008 | 06:39 PM
Trippin's Avatar
Use the Merc assembly's and you'll be fine.
Trippin is offline
Old 03-03-2008 | 06:41 PM
Cool Water pump change
No one knows how to change a water pump in a Sportmaster gear case?????
Old 03-03-2008 | 06:47 PM
Trippin's Avatar
Question
You need instruction?
Trippin is offline
Old 03-03-2008 | 10:40 PM
Default Water pumps Sportmaster
YES
Old 03-05-2008 | 08:09 PM
Trippin's Avatar
4 nuts on cavplate, 1 under torque tab, drop lower unit, remove the 4 nuts on waterpump housing, remove housing, impeller and keyway, replace all with the contents of your new kit, housing if necessary. Apply a light coat of oil or soap to housing. Slide impeller down onto wearplate and keyway install housing while turning driveshaft clockwise, tighten nuts on w/p housing. Re-install lower unit on midsection. That's it , more or less. You can do it.
Trippin is offline
Old 04-06-2008 | 01:58 AM
sunchaser796's Avatar
Make sure you shift the drive into forward gear and turn the shift shaft counterclockwise befor installthe thelower unit
sunchaser796 is offline
Old 04-06-2008 | 04:28 AM
Thats it
Dd24skater is offline
nocigarette
0
06-24-2006 01:37 PM
US1 Fountain
3
01-26-2005 11:03 PM
bcoffield
Baja
1
04-27-2003 06:30 PM
Luv-N-It
04-22-2003 04:37 PM
mopower
7
06-18-2002 04:17 PM
