Questions about load ranges
Old 03-02-2008 | 09:07 AM
DRIVEN1's Avatar
Default Questions about load ranges
I have a 2007 F250 with the factory Goodyear 20s that have a load range of E, I am looking at doing some 325/60/20 Toyo open country on new wheels but they have a load range of D. Will this matter towing a 32 foot center console? What about towing a big gooseneck trailer? Hope someone on here is familiar with load ranges and can help me out. Thanks Mike
DRIVEN1 is offline
Old 03-02-2008 | 10:14 AM
I had the Mud Countrys on my F-250 and they were E -rated,,read the actual gvw sidewall rating on both tires and I think you'll be surprised,,Toyos have always had a higher rating compared to other manufacturers
Bottomfeeder is offline
Old 03-02-2008 | 10:15 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Even the heavy duty E-load rated wheels can fail. This happened to PhantomChaos on his Excursion as one his actually cracked the wheel while towing his 382 Formula to Havasu.
You definately CANNOT skimp on the wheels. Look into wheels from www.wheelpros.com like the MotoMetals,IceMetals, Helo, as well as Welds and Mickey Thompson.
Sydwayz is offline
Old 03-02-2008 | 10:28 AM
Alcoas or the like,, I hate to say it because I'v owned lots of em,,but some Welds=Chinese but most wheel manufacturers are using the "overseas" vendors IMHO
Old 03-02-2008 | 10:40 AM
DRIVEN1's Avatar
Don't plan on skimping on the wheels. But they recommended the toyo open county at. I looked them up on the internet and they are d rated. I do not want to take away towing capacity on my truck.
DRIVEN1 is offline
Old 03-02-2008 | 10:41 AM
DRIVEN1's Avatar
Just going on what the toyo site said, they did not have the tire in stock. They will have them there next week for me so I will check them out then. Thanks
DRIVEN1 is offline
Old 03-02-2008 | 10:42 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Oops, I read your post wrong, but also; you can't skimp on the tires either. Look into BFGoodrich All Terrain KO and the Nitto Terra Grappler as well as their brand new tire.
Sydwayz is offline
Old 03-02-2008 | 10:46 AM
DRIVEN1's Avatar
Don't worry, I will always lean towards spending more money to get what I think is the best. I have been looking at tires and it seems that all 325/60/20 are d rated. Seems every truck I see down here has big tires and wheels and they seem to be towing. I am probably just reading into it more than I should.
DRIVEN1 is offline
Old 03-02-2008 | 11:02 AM
Toyos in that size are rated at 3195lbs in a single wheel configuration what does it say on your Goodyears sidewall?
Old 03-02-2008 | 11:15 AM
DRIVEN1's Avatar
3750 at 80lbs
DRIVEN1 is offline
xhere
1
04-03-2006 08:09 PM
cri331
07-14-2002 09:46 PM
