Rebuild raw water pump body? >
Old 03-02-2008 | 06:58 PM
Default Rebuild raw water pump body?
Not the impeller, but the actual pump body. '91 Mark IV Bravo. I've got one that the shaft is turning rough and a little notchy. The parts diagram shows the internals for the old 2-piece body it looks like. Not sure if the parts are the same or not.
handfulz28 is offline
Old 03-02-2008 | 07:43 PM
offthefront's Avatar
Mike .... I rebuilt one and it worked out fine .... We crossed all the parts from the local bearing Company ... it was about 25-30 bucks .. you can get the parts from Merc though ... seems it was about 50.00 ...
you do need access to a press ....
offthefront is offline
Old 03-02-2008 | 08:09 PM
Thanks Mike.
That'll be the sticking point. So did you use the special Shell #2 grease? Where the heck do I get that?
jdub
7
03-26-2007 05:06 PM
hpy540
1
03-11-2006 05:10 PM
SeaDated
21
08-29-2002 07:20 PM
StrikinLightnin
5
08-15-2002 09:04 PM
SR-24
03-31-2002 07:51 PM
