F-450 blowing fuses
Old 03-04-2008 | 06:26 AM
Default F-450 blowing fuses
I have an 08 F-450. And it keeps blowing trailer fuses for the trailer lights. I have hooked it to a few different boats and it blows it everytime. And these are new boat trailers. Any Ideas?
BobbyB is offline
Old 03-04-2008 | 06:50 AM
Registered User
Buy a round-7 to flat-4 adapter.
Chris Sunkin is offline
Old 03-04-2008 | 06:58 AM
First time was round adaptor to a 4 pin.
BobbyB is offline
Old 03-04-2008 | 07:18 AM
mrv8outboard's Avatar
coolrunning racing
did the truck come with the trailer tow package? it would have both the seven pole rv and the four flat. in either case i would check the wiring schematic it is on the lid to the seven pole socket. also which fuse is it? 10 amp running lights? you could have a bad ground.
mrv8outboard is offline
Old 03-04-2008 | 08:08 AM
Registered User
Ground can do it. If you have alot of lights the bad ground will cause a voltage drop. That makes the amps spike.
Old 03-04-2008 | 06:03 PM
It was a 30amp square fuse. Number 42 in the fuse box in the engine compartment.
BobbyB is offline
Old 03-06-2008 | 06:35 PM
45sonic's Avatar
Ground would be my first guess. If not take it back to the dealer and have them check it. For now you may have to run a separate ground wire to the frame. If you need help this weekend let me know.
45sonic is offline
Old 03-06-2008 | 11:14 PM
scottc's Avatar
If you can't find it stop over my place and I'll straighten it out for ya. Or call me 410-573-9776
scottc is offline
Old 03-07-2008 | 05:36 AM
purnell's Avatar
Thumbs up
Bobby I'll sell u mine
purnell is offline
Old 03-07-2008 | 07:29 AM
I want the cap off your truck.
BobbyB is offline
oreokid220
04-06-2008 04:36 PM
86formula242ls
05-24-2006 08:43 PM
ripley
33
06-19-2005 11:07 AM
outlawntexas
16
09-16-2003 07:56 PM
ArtsWarlock
13
11-05-2002 07:03 AM
