X-Dimension
I don't know if Sutphen standardized the X-Dimension on their boats. If so would anyone know what a 97 34' would be.
Dan do you still go to OP offen? I am looking to get the gear ratio on the outdrives and the prop size. My port prop seemed to cavitate at times. I have no idea where it is I think its in one of the hangers.
I am trying to look to get the best setup for this boat. I don't care about the hole shot, a good top end would be nice but mostly looking for a nice cruising speed.
I am at school in RI so i cant really go anywhere till May. I am friends with the previous owner though. It should say on the props what pitch they are. What i would do is once you find out the X (measure it), and current props give Throttle Up a call and they will provide you with a set up that your looking for prop wise.
Dan I did not relize you were not around. I will have to take a ride up to OP it's just an hour away and there is nothing else up there for me to do. If they were in the city it would be easier to drop in.
Thanks anyways.
Thanks anyways.
