500 efi bolt on hp?
Old 03-27-2008 | 09:02 AM
hangem out 2dry's Avatar
Default 500 efi bolt on hp?
who has a kit with the best gains for a 500 efi 2001 without supercharging?
hangem out 2dry is offline
Old 03-27-2008 | 09:56 AM
BAJA WILL's Avatar
Registered User
I would say leave it, or whipple it. No real in the middle with out pulling the motor apart, and then your at as much as a whipple would be but don't have one.
My 2 cents
WILL
BAJA WILL is offline
Old 03-27-2008 | 09:59 AM
brodix heads and ecu reflash..... 10k id guess
dreamer is offline
Old 03-27-2008 | 10:07 AM
Strip Poker 388's Avatar
Rob
Your best bet is Mark at Precision Marine in Kenner,La(504-469-7463),he can do 600 or 640 pretty reasonable and dependable.He can dyno and tune the ECU and if needed fine tune it at the lake.Rob
Strip Poker 388 is offline
Old 03-27-2008 | 10:17 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Do a search on posts by "Linster" . He has done some nice upgrades to the guys local here in Richmond. I think he has built 6 or so 500EFIs into reliable 600HP/700TQ bulletproof motors with NO BLOWERS.
The Arizona Speed & Marine monoblade throttle body is a nice mod to start with. Then you need to talk about the ECU. After that, there is not much left without going inside, or supercharging.
Sydwayz is offline
Old 03-27-2008 | 11:06 AM
Fountain38SC's Avatar
I guess lower but it's been a couple years since I bought mine. This will give you a bullet proof setup with a nice increase in HP. If you get ambitious, look at cams. Short of getting blown, this is probably your biggest bang for the $. Just my .02
Fountain38SC is offline
Old 03-27-2008 | 12:30 PM
LZH
Each set of heads, polished and ported and built by someone who knows what they are doing...will run you about $5k all said and done. For both motors, labor, ECU flash...you are right around $10k as Ted suggested. I recently spoke with Dean Gellner about doing this to my motors...
LZH is offline
Old 03-27-2008 | 02:07 PM
Elite Marine's Avatar
Call Bill at Ateco (847)623-2737. Has a bolt on kit good for 600+ HP includes the reflashed ECU. Under $ 5,000.00.
Elite Marine is offline
Old 03-27-2008 | 03:09 PM
LZH
Do you know exactly what they do to get 600hp with bolt on mods ? And, what is the reliability and longevety consequences ?
Where is Dean when we need him???
LZH is offline
Old 03-28-2008 | 12:37 AM
articfriends's Avatar
Tyler crockett is supposed to be finishing bolt on plenum tops with a built in throttle body that is re-located, He is having these casted at a foundry and will have them on the market soon. In intital testing he made 630 hp on the dyno with other mods,Smitty
articfriends is offline
