Help?I need 6 1/2 Speaker mount adapter rings
My speaker holes are to big for the 6 1/2 MB Quarts,It had the Polyplanar http://www.polyplanar.com/# which are a (odd ball size
)There mounted on the panel under the seat,it has carpet on the panels.I'm thinking I need some kind of adapter ring .Here is a pick of a ring I found searching goggle, Does anybody have any suggestions and or where can I buy some adapter rings? Thanks,Rob MB is saying the cut out should be Cutout diameter: 5.16" http://www.ikesound.com/product-product_id/2795
sample pick
)There mounted on the panel under the seat,it has carpet on the panels.I'm thinking I need some kind of adapter ring .Here is a pick of a ring I found searching goggle, Does anybody have any suggestions and or where can I buy some adapter rings? Thanks,Rob MB is saying the cut out should be Cutout diameter: 5.16" http://www.ikesound.com/product-product_id/2795sample pick
I used clear plexy, rounded the corner over, polished the edges and stuck black vinyl on the back side to give it deep clear black look. I did step turn the rings ID to fit the speaker almost flush with the front of the plexy so it wouldn't look like it was just placed behind the speaker. A little more custom look to it. Plus I can also change the color of the vinyl if I choose.
How do I cut the ABS with out cracking? I have a jig saw with a fine tooth blade.
