525SC Carbs
Old 04-01-2008 | 06:21 PM
blue thunder's Avatar
Default 525SC Carbs
I have a couple questions if anyone can help regarding Merc 1050 Dominator Carbs that were original equipment on the 525SCs:
1. What is stock merc jetting and PV on these carbs?
2. How is the boost referenced power valve achieved and how can I tell if some 1050 blue carbs are actually blower carbs?
BT
blue thunder is offline
Old 04-01-2008 | 09:25 PM
Jets should be #98 all around. The carb is not boost refered, if I remember correctly PW is 6.5.
bl
badluck is offline
Old 04-02-2008 | 01:38 AM
bl
98's and 6.5's is correct. Stock jetting is rich. Not sure about the boost referencing. Mine did have a hose and pvc valve going to the carb base. My jetting was stock with 98's even with 7.5-8#'s of boost and it was fine. Went up about 4 sizes when added a roller cam.
Griff is offline
Old 04-02-2008 | 04:05 PM
Thanks for the replies. It sounds like merc jetted like there was no power valves thinking they will never open anyway.
BT
Old 04-03-2008 | 06:46 AM
Blue Thunder- What jetting was in your carb? 98's? .... Does your carb have Power valves or not?
I have re-jetted many of these engines. I would run 93 jets square with a 6.5 power valve in the primary and 5.5 in the secondary. From stock jetting , on average the boat will pick up about 2 sometimes 3 MPH. Mercury likes to flood engines with fuel. I hope this helps.
mrhorsepower1 is offline
Old 04-03-2008 | 11:09 AM
They have 98s square and 6.5 front and back. They were supposed to be stock and I just wanted to make sure. I was curious why merc would choose not to do the boost referencing? Do you boost reference MrHP when lowering the jets and PVs?
Old 04-03-2008 | 11:37 AM
I have boost referenced before, The carbs are under vacuum , running power valves is just fine. Run the jetting I stated above, if want want to start a bit richer install 94's. The engines will wake up! The other thing I want you to do is set the float levels with the bowl off. Invert the bowl (up side down) and with a pin gauge or clean drill bit, set the floats at 23/64 or .3594 measured in the center of the float/bowl. This will correctly set the floats so they are not too low or too high. The gauge should just slip under the top of the float.
Old 04-03-2008 | 12:00 PM
Thanks much MrHP. I'll take that advise.
BT
Old 06-27-2008 | 06:20 PM
Would the same jetting apply to a 525sc that has an intercooler? I have one and right now it is jetted richer, plugs read rich=safe. I know there is room for improvement.
Old Navy is offline
Old 07-16-2008 | 07:42 PM
Anybody??
Old Navy is offline
AS IS
15
03-30-2011 11:30 AM
YOLO
05-16-2008 08:51 PM
randy carlson
Wanted
3
03-14-2008 03:08 PM
sneekinfreek
7
03-18-2007 01:58 PM
Donzi Black Widow
12
11-02-2004 12:02 AM
