Sea Pump leaking oil? >
Old 04-05-2008 | 08:52 PM
Default Sea Pump leaking oil?
Was playing around with my new to me boat today. Noticed what looked like grease "slung" in the bilge. The line of grease/oil seems to line up with the sea pump pulley. Its not motor oil, its too thick and blackish gray in color. I am pretty sure its got to be leaking from the sea pump.
Does merc have a seal and bearing kit for these old style pumps? Its the Gen IV pump.
MILD THUNDER is offline
Old 04-05-2008 | 09:14 PM
offthefront's Avatar
yes it is the pump ...
Part .... # 13 15 16 19 and if you need the shaft #17 ....m
http://www.mercruiserparts.com/Show_...SEA+WATER+PUMP
offthefront is offline
Old 04-05-2008 | 10:10 PM
THANKS! Thats what I was looking for!
Old 04-05-2008 | 10:29 PM
Wobble's Avatar
SORE MEMBER
Could it be that your belt is slipping, that will leave a black carbon type line also.
Wobble is offline
Old 04-05-2008 | 10:33 PM
Nah, its definitly a oily grease residue. Its actually splashed on the stringer(portside) and underside of hatch. Probably leaking from the pump shaft, then getting slung clockwise from the belt/pulley.
Old 04-05-2008 | 10:45 PM
there is a hole in the housing ...when the seal starts to leak water/grease comes out of the small hole .....m
Old 04-07-2008 | 11:59 AM
Jerry B
If you have the mechanical fuel pump bolted to the sea pump make sure it not leaking fuel into the pump housing. It will delute the lube thats in there. I think it uses the same lube as your outdrive uses. I had this happen on one of mine. Had to replace front seal and fuel pump. I took the seal to an auto parts store and they had a match.
Jerry B is offline
BillR
11
07-29-2022 06:31 AM
Nauti By Nature
4
11-09-2008 09:19 AM
cloudmaster_321
0
07-07-2008 04:09 PM
HP500Hammer
15
01-30-2008 06:03 PM
BillR
4
02-06-2007 03:23 PM
