bleeding surge brakes
you can try gravity bleeding,but ive had great luck using a ''miti-vac'' vacum bleeder system,its a small hand pump and a cup and 2 plastic hoses,hook 1 th the bledder screw,1 to the pump and 2 other ends the cup,pump the hand pump and open the bledder ,do this 2-3 times and your done
1 Person bleeding. Put a legth of clear vinyl hose over the bleeder screw into a clear bottle (I use a 16oz. pepsi bottle) half full of brake fluid and pump away.
I've completely changed the fluid in 2 trucks, my corvette, my Corolla, and the trailer this way.
works like a charm.
You'll use some brake fluid this way because once you have some contaminated fluid in the bottle you toss it, but it's cheap.
hint: use synthetic or a synthetic blend brake fluid. Higher boiling point and doesn't attract moisture like conventional.
works like a charm.
Does the cap on your reservior have a plug in the top? If it does, you can remove the plug and there should be a small nipple fitting there. You can use a compressor and air nozzle to apply steady pressure to the system through the fitting.
This is a 2-person job and you need to make sure the fluid level is maintained in the reservior, or you will have to start all over.
Always bleed the system starting from the furthest point away from the reservior and work toward it.
t500hps
25
08-16-2005 09:05 PM
