Kiekaffer Controls.... >
Old 04-10-2008 | 06:42 PM
Default Kiekaffer Controls....
how do i replace the cable's. sounds like a silly ? but i don't really see how to remove cable's . any help ? thank's.. also there about 1986 era.
scarabfun is offline
Old 04-10-2008 | 09:07 PM
offthefront's Avatar
there is a pin that slides thru all 4 (or 2) cables ..pull the cotter pin and then pull the pin ...then you can rotate each cable .... you have to rotate it pretty far to get it to release from the fork on the throttle ...m
offthefront is offline
Old 04-10-2008 | 09:38 PM
thanks, i got the pin part but wasn't how to get it off at the top. i thought that was how but wasn't realy sure.thanks couldn't find any manuals on them.
Old 04-11-2008 | 05:48 AM
Just make sure when you rotate the cable you dont break the outer cover of the cable ...meaning the aluminum end ...you can breakor bend the end of the outer cable when your trying to pivot the cable up to remove it from the controls ..m
yss
9
01-31-2018 09:03 PM
Enforcer2
Do It Yourself, Boating on a Budget
15
02-20-2008 09:09 PM
bsirk
Detailing, Painting, & Fiberglass
13
04-18-2007 09:09 AM
mtgbiker
7
06-28-2006 09:29 AM
superboat1989
Superboat
4
11-30-2005 12:07 PM
