Shueman?
Old 04-29-2008 | 12:20 AM
Default Shueman?
Do you know generally what speeds the eagle 25 hull will start to chine walk at? I know it varies greatly, but mine is a factory rigged install, so i'm sure it was done right..Will the tabs truly help or is it just gonna be unstable around 80? Design limitation?
Thanks!!
Yellow_ICC_OK is offline
Old 04-29-2008 | 08:18 AM
Registered User
Thanks!!
Not my area of expertise... I'm sure that others will offer up their comments, and I can ask Tony at the shop...
shueman is offline
Old 04-29-2008 | 02:59 PM
85-90 ours started to chine top speed was 108mph was alot to handle.You need to learn to balance it if you look at the rear of the boat it sits on a 5 inch flat pad and at speeds you blalance it there.
B BOATER is offline
Old 04-29-2008 | 05:16 PM
Default Cool
Thanks for the info. I cant imagine an eagle running 105, it would HAVE to be squirrely as heck!!
I'm gonna check my steering over really close, I think it might have some play in it. I have the dual ram add on, and there is a little delay in it, plus I think the steering effort is too high i think.
Old 05-01-2008 | 01:39 AM
Registered User
If you are approaching those speeds you defiantey need full hydro to the helm.
320es is offline
ILMORdude
Eliminator
1
10-09-2008 09:11 PM
B BOATER
Eliminator
55
04-20-2008 08:32 PM
ILMORdude
Eliminator
3
03-04-2008 08:55 PM
