502 efi mechanical fuel pump gear oil change... >
Old 05-15-2008 | 12:54 PM
Default 502 efi mechanical fuel pump gear oil change...
Is the drive oil supposed to be used in the gear box for the fuel pump, or some other type of lubricant? This is on a 96 502 efi.
Ryan
cloudmaster_321 is offline
Old 05-15-2008 | 02:41 PM
Knot 4 Me's Avatar
Merc High Performance Gear Lube.
Knot 4 Me is offline
Old 05-18-2008 | 01:59 PM
Well, i took the whole pump assembly off the motor so i could open it up and get out all the oil. I found some brown gas diluted mixture. Which from my research is the reason why this is supposed to be done every year. The cam arm on the fuel pump only shoed a visual wear mark, nothing pyshical. So i added the drive lube up to the plug, new gasket, and put it back together. Along with a new impellor kit.
Thanks for the help.
Jim Diesel
2
09-03-2008 07:40 PM
cloudmaster_321
Do It Yourself, Boating on a Budget
0
07-08-2008 08:57 PM
Dock Holiday
6
10-10-2007 06:52 PM
cloudmaster_321
12
08-08-2007 10:30 AM
BeakBoater35
4
08-29-2005 08:33 AM
