Anybody know anything about this Ignition System? >
Old 05-19-2008 | 10:22 AM
Default Anybody know anything about this Ignition System?
It is a firepower by nutek. Trying to figure out if you can change the rev limiter or if it has a rev limiter.. Also is it any good?
I'm tempted to through a GM hei w a accel super coil in it w some weights. Do HEI 's foul up in the moisture? I wonder why people aren't running them..
Thanks....Chad
mcprodesign is offline
Old 05-19-2008 | 10:25 AM
Originally Posted by mcprodesign
It is a firepower by nutek. Trying to figure ouot if you can change the rev limiter or if it has a rev limiter.. Also is it any good?
Thanks....Chad
They are....I am running them....All the 500EFI's ran them. EDDIE marine sells the voyager hei conversion kit.
Westcoast is offline
Old 05-19-2008 | 10:29 AM
BY U BOY's Avatar
I have no problems with my HEI.
BY U BOY is offline
I have like 3 of them siting around here from various camaros I have had. Can I use one of those? or is the fire power better??Thanks..Chad
Old 05-19-2008 | 10:48 AM
I don't know anything about the firepower system...What don't you like about it?
Old 05-19-2008 | 12:08 PM
I guess I don't know anything about it too.. And its old and I can't figure out the rev limiter..That is what I don't like about it ..
If I put an hei. I may have to make a new oil cooler bracket..and tune it in and it will take time to do that..so right now I'm torn..Hoping someone can tell me what to do with this..My engine builder said he would like to see 5800..He is a ways from here and I would like to figure this out on my own and not take a lot of his time with it ..He does the engine building. That's enough
Old 05-19-2008 | 12:18 PM
Mbam's Avatar
Offshoreonly Advertiser
We ran those years ago. There is a rev-limiter but it is not adjustable.
Mercury actually used them for a brief time if I remember correclty. Holley bougt them out.
Mbam is offline
Old 05-19-2008 | 01:13 PM
Thanks a ton!
Do you have any recomondations on a differen't ignition?/Would I need to change the distributor too?
Thank you .Chad
Old 06-30-2024 | 07:18 PM
phughes69's Avatar
Chad, did you ever figurte out the wiring colors
phughes69 is offline
Old 07-01-2024 | 07:43 AM
The small GM HEI EST distributor works as well as any and there shouldn't be any clearance issues.
snapmorgan is offline
rockstar38
7
07-02-2008 05:18 AM
jdub
4
02-27-2007 07:42 PM
fastlane40
13
11-02-2006 01:34 AM
MILD THUNDER
2
08-02-2005 01:39 PM
ofshore
8
10-05-2003 08:05 AM
