Mercruiser Tunderbolt distributor >
Old 06-11-2008 | 10:08 AM
QUIKDECISION's Avatar
Default Mercruiser Tunderbolt distributor
I have no spark on one of my 454 mags. I swapped the amplifier
and coil from one engine to the other. Still no spark in the problem one, I assume it is the distributor,i.e. the magnetic pick up sensor. All of the parts I removed work fine on the other engine. Anyone have one of these
that they would be willing to sell?
Thanks for the time.
Quikdecision.
QUIKDECISION is offline
Old 06-11-2008 | 10:17 AM
Wally's Avatar
Were doomed!
Swap distributors and see if it follows....
If you still need one i have one that a "buddy" had me buy for him thinking he needed one and turned out it was a bad cyl in the motor so now i have this collecting dust! If you want it you can have it for what i paid for it $60 + shipping.... Its complete with the cap too...i have no use for it
-Wally
Wally is offline
Old 06-11-2008 | 11:18 AM
Wally, sent you a PM.
Old 06-11-2008 | 01:06 PM
$60.00 is the standard merc price for a new pickup. there is a procedure for testing the system.
JIMG is offline
Old 06-11-2008 | 02:11 PM
tssteph's Avatar
I chased the similar problem this weekend. Ended up being a broken wire coming out of the distributor and into the loom. If I recall they are both tan one with a red stripe and one with a blue. Use a ohm meter/volt meter and check them both with the key on and compare it to your other motor. Mine also had a fuse coming off the starter up into the loom.
tssteph is offline
Old 06-11-2008 | 02:20 PM
Test procedure:
http://www.marinemechanic.com/site/page251.html
rdoactive is offline
Old 06-11-2008 | 02:21 PM
Quik order out the pick up , had the same prob .If you want the test procedure out of the merc manuel to be 100% positive p.m. me your fax # and i'll shoot it across it'lll take ya 10 mins good luck
Old 06-11-2008 | 05:46 PM
blue thunder's Avatar
Check for 12v on the + side of the coil (purple wire) with the key on.
blue thunder is offline
Old 06-11-2008 | 08:58 PM
Hey Everybody....
Thank you so much for your responses.
I ohmed out the wires on the distributor, just as TSSTEPH had suggested. I had a broken wire. I took pics, too late to load tonight.
Thanks again everyone.
Quik
Old 09-20-2008 | 06:27 PM
Default flat line
hey anybody have a problem with sensors telling the t-v to flat line at 4000rpm, can i just unplug the knock sensor and jump a wire to get to winterizing time??
kevinandlaura is offline
SCARAB98
4
09-26-2007 12:16 AM
offthefront
2
07-03-2007 08:24 AM
Ken N
03-31-2007 03:07 PM
excursion
14
03-22-2005 05:13 PM
Milord
10
02-28-2002 05:09 PM
