Hyd steering presure adjust at idel? >
Old 06-20-2008 | 10:44 AM
Canada Jeff's Avatar
Default Hyd steering presure adjust at idel?
Since the suprercharger last summer, I noticed my hydraulic steering has become tough to work when docking at idel. Bump up the rpm to 1000 and it's fine. Is there a presure adjust to this system. The pump is stock, Merc hp500efi, the rest of the system is IMCO .
Canada Jeff is offline
Old 06-20-2008 | 01:54 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Add on or full Hyd?
RPM is the factor, so I assume you dropped the idle RPM from the motor change?
US1 Fountain is offline
Old 06-21-2008 | 09:48 AM
hoozeyurdaddy's Avatar
I have the same problem, has done since installed, full hyd, with power assist, Imco sys. 1000 - 1200 rpm great, under 1000 harder than H---
Larry
hoozeyurdaddy is offline
Old 06-21-2008 | 11:15 AM
Full hydraulic should not be hard to turn at idle. I can turn mine with 2 fingers at a 700rpm idle. There is an orifice fitting you can drill out where the high pressure hose connects to the pump also.
Griff is offline
Old 06-21-2008 | 11:05 PM
Here is a link to an article about this modification...
http://westtexasoffroad.homestead.co...rsteering.html
Doug
Boatally Insane is offline
Old 06-22-2008 | 09:10 AM
Doug
Just read the link, thanks, I will give it a try.
Larry
Old 06-22-2008 | 10:14 AM
Was the pulley ratio changed with the other changes?
Falcon is offline
Old 06-22-2008 | 03:18 PM
exactly. somewhere somehow along they way you slowed the pump down and it wouldn't have to be much at all to do exactly this.
stevesxm is offline
Old 06-23-2008 | 06:02 AM
No same pulley, same RPM at idel, Full Hydraulic steering.
I've had the problem since the supercharger was put on.
I'll read that article posted above.
Old 06-23-2008 | 06:09 AM
Maybe just a pulley change would be easier than removing the pump and drilling pieces out.
I'm going to try buying a smaller pulley first.
