Blower boost,Merc 600 SCi
If it has Smart Craft you can toggle through the pages to find it. Its under manifold pressure, I think. 4 lbs, sticks in my mind, but not sure. We had them in a 38 Fountain. Im sure Dustin Whipple knows. I know when you hit the rev-limiter, a message comes on the smartcraft screen saying it was reducing power. I guess by a boost bypass.
Dustin
4.5 psi boost.
620 - 635 crankshaft hp and around 820 Nm torque, seems to be what the stock motor delivers.
The power peaks at around 5100 - 5200 rpm, so propping to run to the (5350 rpm) limiter doesn't usually produce the best top speed.
Dustin
