thunderbolt ignition wiring
Hello,
I'm going to change my distributor and need a wiring diagram to install ,it's a thunderbolt 4 with a 22a advance module. it has purple and gray wire's. Also do I need to ground anything the set the base timing ,this distributor is around a 1988 module which is new. Thanks Alec
Don't worry about base timing. Bring the motor up around 3000 rpm and set the total advance timing. I have mine set at 37* Some guys only like 34 - 36 . I have the v 24 module and only get 20* advance out of it.
