2004 22 velocity, 300x prop and set up? >
Old 07-08-2008 | 03:33 PM
Default 2004 22 velocity, 300x prop and set up?
looking for any advice on prop choice and set up on jack plate THANKS!
Buford T. Justice is offline
Old 07-09-2008 | 11:58 AM
for all around i would get a lab finished bravo 1 4blade with vent holes. contact brett at bblades.
cowisl is offline
Old 07-11-2008 | 11:04 AM
bbladesprops's Avatar
Offshoreonly Advertiser
Smile
Believe it or not we used to run Trophy small hub props on those boats with 3 litre motors.
But now cowil is right. 14.75" diameter cupped Bravo 1 props with vent holes are the ticket.
[email protected]
bbladesprops is offline
Old 07-16-2008 | 01:07 AM
I'm running a 24 pitch bravo right now thats been labbed by a local company (probably not the best job) and can only get about 6200 rpm's. The limiter is at 6800, so do i drop to a 22 pitch or would it be worth it to swap the 1:62 ratio lower unit for a 1:75. any major speed gains?
yousif
Prop Talk
1
04-25-2007 09:02 PM
Cincinnati Race
General Racing Discussion
13
06-21-2004 04:31 PM
LA3
2
05-24-2004 03:04 PM
Strike
11-17-2003 10:25 AM
waden54
Velocity
4
05-11-2002 02:55 PM
