1996 7.4 carb. ignition  timing >
Old 07-11-2008 | 02:03 PM
JIM H's Avatar
JIM H
Default 1996 7.4 carb. ignition timing
I need the procedure on timing.
Thanks is advance
Jim H
JIM H is offline
Old 07-12-2008 | 08:49 AM
hoozeyurdaddy's Avatar
nothing hi-tech here, should have a 20 or 24 deg. module, just set base timing at 8 deg. and check the max timing, should be you 8 deg plus what ever the module is. should run good between 32 and 36 deg. max advance. make sure you check your max adv. with engine at 3000rpm or a little higher.
hoozeyurdaddy is offline
Old 07-12-2008 | 12:44 PM
JIM H's Avatar
JIM H
Thank You
I was told that i have to ground out a purple wire with a white tracer.
If i need to make any adjustments. Is that so ?
JIM H is offline
Old 07-12-2008 | 05:15 PM
thats not needed with your set up, just set it.
Larry
kcvega
8
07-15-2010 01:39 AM
prostockcat
3
06-14-2008 12:37 PM
bsc
3
05-17-2006 02:09 PM
mtocrs1
6
04-18-2006 12:35 PM
THRILLSEEKER
8
02-25-2003 09:07 PM
