No spark with MSD all in one >
Old 07-16-2008 | 07:16 AM
wieland77's Avatar
Default No spark with MSD all in one
Over the weekend i was running fine and all at once lost spark, also tach. Really wierd but the coil came loose from the holder and was dangling at the back of the engine. I grabbed the coil and found a broken wire at one of the terminals (the tach wire) and the spark wire going to the dirstibuter cap was broken at the top of the coil. So i replaced the coil and the coil wire, tightened everything back down and still no spark. I have the MSD "all in one", 8560 i think, and i was thinking the only thing left would be the pick-up in the dist itself, right? Can these be changed out? Where could i get a pick-up for this dist other than MSD if it is available? Thanks, MIKE
wieland77 is offline
Old 07-16-2008 | 10:28 AM
offthefront's Avatar
yes you can .... 84661 ....
http://store.summitracing.com/partde...5&autoview=sku
All MSD billet distributors use the same pickup ...They do go "bad" ...... you might try local speed shop .....should be about 20.00 ..... m
offthefront is offline
pkspx
61
08-20-2015 09:06 AM
snake plissken
07-15-2007 02:30 AM
osen007
0
05-29-2007 04:27 PM
ofshore
4
07-15-2003 05:36 AM
