Perko Wiring for Dual Battery Setup >
Old 07-18-2008 | 02:16 PM
Krumbsnatcher's Avatar
Default Perko Wiring for Dual Battery Setup
Guys,
Here is my propsed wiring for a dual battery setup, do you see anything wrong with this setup.
Battery #1 is my starting battery, along with the helm power that supplies the radio and amps relay to fire.
Batter #2 is two deep cell batteries that provide the power to the amplifiers. I have the auto amp wire on a toggle switch so when i pull near a dock i can kill the amps and let just the radio's amplifier power 4 small 6.5's two in the cabin and two in the cockpit.
The Power to the amplifiers is 4 gauge with a 180 Amp Circuit breaker.
Ok thats about it besides the stereo equipment installed. Just wondering if this steup will work.
thx in advance
Krumbsnatcher is offline
Old 07-18-2008 | 02:44 PM
satisfactionII's Avatar
I set mine up just like you have it drawn. Works fine for 3 years.
satisfactionII is offline
Old 07-19-2008 | 07:04 AM
cig1988's Avatar
How about a schematic for twin engines, two perko switches and three batterys?
cig1988 is offline
Old 07-19-2008 | 01:02 PM
That is what I have.
I have Bat 1 on each switch wired to the separate starting/main battery for each engine. Bat 2 from both switches is wired to the 3rd big deep cycle battery that I use for the stereo. Just don't run both switches on Bat 2 at the same time. This will allow any of the 3 batteries to start either engine.
Griff is offline
Old 07-20-2008 | 05:26 AM
cig1988's Avatar
Hey Griff
Whoever had the boat before may have screwed with the wiring. It came with two massive size batterys with a million ground leads on the port side. There is evidence on the stringers that 3 boxes were once there.
Port side perko on #1 will draw from port battery. Starboard side perko on #2 will draw from starbaord battery. If I turn SB side perko to #1 it will draw from port side.
cig1988 is offline
gferdon
Fountain
10
01-20-2005 09:39 PM
MiamiVice
17
12-23-2004 10:25 PM
buck183
8
08-09-2003 08:04 AM
Kentz
Powerquest
19
06-10-2003 05:45 PM
Julio
Powerquest
3
02-22-2002 07:34 AM
