Procharger
Old 08-06-2008 | 04:51 PM
Wodster69's Avatar
Default Procharger
What would be needed to convert a 500efi kit to a 502mag efi.
How hard of a job is the install and making it run right?
David
Wodster69 is offline
Old 08-07-2008 | 10:18 AM
If the pulley system is the same only the plumbing to the throttle body should be different.
kennyo is offline
Old 08-07-2008 | 02:43 PM
nice avatar....looks like you might find what you're looking for.......
Bryan Rose is offline
Old 08-07-2008 | 03:44 PM
Talking
Lookin' for love in all the wrong places......
kennyo is offline
Old 08-07-2008 | 05:26 PM
you must be because I don't think Fabio hangs out here....
Old 08-07-2008 | 07:31 PM
Wodster69's Avatar
Hey if you dont like my avatar you can "kiss my A$$"
Old 08-07-2008 | 08:00 PM
Not yours....
To answer your question The kit will consist of different things, the brackets will be a little different in the mounting points, It will also depend on if the 502 mag iS serpentine or a V belt set up. Also depending on the year of the motor cool fuel and accessory locations etc. If you are a skilled mechanic and able to shim brackets and such it will be no problem on the install, just be prepared to relocate some stuff, the intercooler for a 500 efi is a remote mount because of the intake location , however if installing it on a 502 mag no problem to put it on the front of the motor and route the intake to the side....Does all this make sense? Both kits are basically the same with the exception of a little hardware....
Bryan
Old 08-07-2008 | 10:21 PM
ZXXX Donzi's Avatar
What he said.
The blower mounts a little higher on the 500 EFI
ZXXX Donzi is offline
baja27
07-31-2006 08:21 PM
BY U BOY
08-09-2005 04:10 PM
baja27
2
04-16-2004 10:10 AM
Freekazz
7
02-11-2004 10:04 AM
Red 230sx
0
10-17-2003 08:32 AM
