Will this trailer fit under my boat? >
Old 08-11-2008 | 08:25 AM
Default Will this trailer fit under my boat?
Does anyone know if this trailer will support the steps on my boat? 2000 Powerquest 380 Avenger. If not how big of a deal is it to redo it to make it fit?
Here's the trailer.
http://www.offshoreonlyclassifieds.c...o23602-en.html
Here's the boat.
NKissau is offline
Old 08-11-2008 | 08:33 AM
I think your in good shape with it.
Maybe have to cut down the rear bunks a little ,because the step on it is higher then yours.
DareDevil is offline
Old 08-11-2008 | 03:37 PM
Thanks devil, I found out the trailer was built for a Hustler 388Slingshot. Anybody know if it's the same or similar to my powerquest? I don't mind making a few minor adjustments but don't want to rebuild it either.
NKissau is offline
Old 08-11-2008 | 06:01 PM
FASTTIMES's Avatar
Thats a nice trailer, was probably twice the asking price new. It would probably be worth paying to have the bunks adjusted to your PQ- - Good luck
FASTTIMES is offline
Old 08-11-2008 | 08:16 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Here's the trailer.
Here's the boat.
I put a message into a friend of mine. He had a steel trailer under a 38 Top Gun that was completely redone; paint, LED lights, wiring, running gear; the works. His boat is a straight bottom. All you would probably need to do is double or triple a couple of the rear most bunks for adequate step support.
I don't know if he sold it or not, but I'll find out.
Sydwayz is offline
Old 08-12-2008 | 04:37 PM
rjr
The factory trailer for my Formula 382 is rated at 20,000#. I figure that I am near 15K loaded & fueled. Your boat may be a little lighter but do you really want to be that close to the max limit of the trailer?
rjr is offline
Old 08-12-2008 | 04:49 PM
I figure my boat with a full load of fuel is right at 11,000. Thanks for the replies, not the ideal trailer, but seems like a good price and it's in good shape. It's 1/3 the price I've been quoted for new.
NKissau is offline
Old 08-14-2008 | 08:03 AM
rjr
I was wondering how two 38' boats could be 1 1/2 tons different when I realized my calculation included the trailer at 2600#. So your trailer might be a little light. Check the axels to make sure they can handle the load.
rjr is offline
Wild
10
11-03-2007 07:33 PM
Harper220
02-14-2006 12:41 PM
Mr. Demeanor
09-15-2003 12:56 AM
Dean Ferry
09-05-2003 02:15 PM
kook
04-09-2002 08:40 PM
