Carb float level adjustment >
Old 08-11-2008 | 01:55 PM
rslick's Avatar
Default Carb float level adjustment
Should the floats be adjusted on the trailer or in the water?
rslick is offline
Old 08-11-2008 | 02:10 PM
DRIPPINWETII's Avatar
I would think in the water.
DRIPPINWETII is offline
Old 08-11-2008 | 03:47 PM
In the water or with the trailer/boat sitting at the same angle on a slope just as it would be in the water.
Griff is offline
Old 08-11-2008 | 11:04 PM
rslick's Avatar
Thats what I was thinking. Thanks for the responses.
SLick
rslick is offline
Old 08-12-2008 | 02:40 PM
Actually it doesn't matter....
Just make sure you adjust them the same way each time, and that there isn't any fuel dripping out of the boosters when the engine is idling.
The reason it doesn't make any difference is that you need to ADJUST them for your specific combination. There is not a one setting is perfect for every boat. So you start with a setting, and adjust it until you get the results you're looking for.
RumRunner is offline
Old 08-12-2008 | 03:00 PM
Wobble's Avatar
SORE MEMBER
from a safety point of view I would recommend on the trailer and hose with trailer jacked up to reflect typical attitude in the water.
Wobble is offline
Biggus
8
06-02-2004 06:42 AM
Formula Outlaw
15
02-15-2004 12:04 PM
Formula Outlaw
01-11-2004 01:14 PM
MIKE H
2
05-31-2003 08:48 AM
BAD-HABIT
18
04-22-2003 03:16 AM
