Timing retarding itself?
What would cause timing to retard 6-8 degrees under acceleration with a locked out msd distributor and the motor has cam buttons? It is a 350 with a med cam noting to crazy sounds like a chain streaching ?
What kind of cam? Roller, solid, hyd, hyd roller? I would say it might have chewed up the gear if the gear on the distributor is not for your type of cam. Everytime I have seen chains stretch they have destroyed motors... valves hitting pistons, etc.
Just trying to help a brother out.
Solid cam and lifters and the gear looks fine. It has bronze gear. Set the timing at 42 @idle rev to 4500 it retards to 37-38 Also @ idle you can watch the light back and forth slowly. Hmmmmm
