Timing retarding itself? >
Old 08-27-2008 | 08:33 PM
MIKE, buy them . Thats a good deal and is what you need.
C-YA !!
DareDevil is offline
Old 08-27-2008 | 10:30 PM
Panther's Avatar
Frank's Marine Service
Originally Posted by GoFastSonic
Motors are coming out this winter should I go with gear drives?
I've heard bad things about the gear drives.... Something about harmonics on the gear drives in a boat. Either Cloyes Billet double roller or Jessel from what I hear.
Panther is offline
Old 08-28-2008 | 02:38 AM
kubcat's Avatar
My counter rotating 260 Mercruiser had a gear drive from the factory. It had no idler gears so it made the cam spin in the opposite direction from the crank.
Never had an issue with it but only running to just over 5000rpm.
kubcat is offline
Old 08-28-2008 | 04:09 AM
Gear drives = NO
Belt drives = YES
A new chain and new cover is just fine though.
Griff is offline
Old 08-28-2008 | 07:22 AM
Panther's Avatar
My fathers boat also had a reverse rotation engine when I was a kid and didn't have problems either but the gear drive's with the idler pulleys he's referring to I hear there are a lot problems in boats. When I was a kid a few friends installed the gear drives in their cars because they wanted people to think they had a blower under the hood because of the whining noise it made....silly isn't it!
Panther is offline
Old 08-28-2008 | 08:09 AM
Here is the picture of the cam stop. If you are racing, you show have some sort of cam stop/movement control system.
File Type: pdf
BenPerfected is offline
Old 08-28-2008 | 08:19 AM
gear drives eat up h/p so they will hurt the power, belt drives use the least, right now if you have steel front timing cover just bent the cover back with a bar or something, you just have to much clearance betwwen the the button and the cover, just do little at a time till timing stays...Rob
ezstriper is offline
Old 08-28-2008 | 05:34 PM
I found a bolt and nut on the timing cover hiden between it and the water crossover. Looks like just a small adjustment. This is the stuff you have to deal with when you did not build or install the motors yourself. LOL Thanks for everyones help.
Mike
GoFastSonic is offline
articfriends
13
01-07-2009 03:00 AM
tomas_wallin
7
05-26-2005 02:06 AM
trobertsuk
5
03-09-2004 06:22 PM
220BR
2
01-07-2004 05:12 PM
Scott
2
07-22-2002 11:01 AM
