nobody uses spark plugs >
Old 08-29-2008 | 10:49 AM
ak
Default nobody uses spark plugs
Why is it when ever i post a question on here no one replys?i try to help who ever i can when i can,but no one helps me,i posted a question about what spark plugs people use and got no replys,i guess no one uses plugs but me.funny i posted the same thing on baja marine and got a dozen answers quick-AWESOME!
ak is offline
Old 08-29-2008 | 10:58 AM
I use NGK BR 6 FS !!!
DareDevil is offline
Old 08-29-2008 | 11:24 AM
Sometimes more details are needed. Just saying "509, aluminum heads, big cam" isn't enough info for these guys to answer the question.
btw.... I use NGK BCP6ES ..... 557, 315 AFR's, Wilson intake, rmbuilder cam, lots mo'dan 620 hp LoL
Kidnova is offline
Old 08-29-2008 | 01:52 PM
BY U BOY's Avatar
I use r43xls.. People need to know what set up you haveto give you and answer that won't blow your chit up.
BY U BOY is offline
Old 08-29-2008 | 05:46 PM
blue thunder's Avatar
I use ngk v power R5671A-9. These are in a blown 454 application so I did not think it would apply
If you said blower motors I probably would have replied... But I do understand the feeling; be persistent!
blue thunder is offline
Old 08-29-2008 | 06:05 PM
I am using Autolite 3911...did use NGK -8. I would say any brand plug in this heat range for a NA low compression BBC application.
BenPerfected is offline
Old 08-29-2008 | 10:02 PM
Smitty's Avatar
I use NGK's
What is your application ?? Had you posted that you might have gotten more answers.
Smitty is offline
Old 09-01-2008 | 04:51 PM
Us too !!!!!!!
formula 382 sr-1 is offline
Old 09-01-2008 | 06:25 PM
my crystal ball very cloudy on your set-up.....but i use accels, love them
ezstriper is offline
Old 09-01-2008 | 06:41 PM
Dave1972's Avatar
AC Delco MR-43T for stock 502EFI and they are just fine. If not in salt the AC R43T works just fine
Dave1972 is offline
